AFR / Timing Advance; MAP Based?
Old Sep 3, 2021 | 09:48 AM
60Gunner's Avatar
Default AFR / Timing Advance; MAP Based?
Is the air/fuel ratio MAP based or throttle position? How about timing advance? I assume the AFR is MAP. If so is it in KPA or INHG?
Old Sep 3, 2021 | 02:49 PM
Highhorse's Avatar
AlexJag may be able to answer those Q's....
Old Sep 3, 2021 | 09:41 PM
motorcarman's Avatar
I guess it would depend a lot on what engine management you are discussing.
Marvjones
Apr 29, 2021 03:07 AM
iramphal
May 4, 2018 10:14 AM
Richard_gib
Oct 21, 2017 01:47 PM
smgdata
Oct 13, 2016 07:08 AM
