After taking my 308 out of storage, problems...
Old Mar 18, 2015 | 04:34 PM
Road Racer's Avatar
Default After taking my 308 out of storage, problems...
After taking my 98 XJR out of storage, I am getting a Stability control failure, Traction control failure, ABS light and air bag light...
Sometimes they shut off but then come back on. When I engage my Sport tranny
it stays stuck in first gear and my blinkers do not work?? What the heck? I have to pull over shut off the car disengage the sport tranny and then it starts shifting again and my blinkers start working again. But the dash lights are still on.
Has anyone experienced these problems???
Old Mar 18, 2015 | 04:47 PM
Mark SF's Avatar
Sounds like low battery voltage to me. Did you have any trouble with it being flat?
Old Mar 18, 2015 | 05:33 PM
badger2196's Avatar
Battery is definitely worth a look when having these multiple electrical issues. Mine had the ABS/traction warning for a few days after coming out of hibernation but they went away all by themselves so not sure what causes that.
Old Mar 18, 2015 | 06:04 PM
Mikey's Avatar
The batteries in these cars should be kept on a tender (not charger) during storage periods longer than a month or so.
The faults you're seeing are common.
Old Mar 18, 2015 | 06:52 PM
Road Racer's Avatar
Thank You... I never thought of that, I just put the tender on it, hopefully she will be fine tomorrow morning...
Old Mar 20, 2015 | 06:05 AM
Road Racer's Avatar
Well, the problem still exists after charging the battery. I brought the car to AutoZone for them to test the battery, he hooked it up and said the battery was fine and taking on a full charge. When he asked me to start the car so he could test the alternator, he said the tester showed a disconnect and could not test anything... The battery was very hot to the touch and the positive cable looked like it started to melt the battery, I could not touch the cable because it was too hot??? Could the battery be bad?
Old Mar 20, 2015 | 08:29 AM
RJ237's Avatar
It sounds more like a short in the charging circuit, maybe the alternator itself.
Old Mar 20, 2015 | 09:19 AM
Mikey's Avatar
That's a very serious short to ground. Disconnect the battery before something catches fire. Is it possible that animals chewed the wiring while the car was in storage?
Old Mar 27, 2015 | 05:00 PM
Road Racer's Avatar
RJ237 You were right! I got my car checked out today... Found out it was the alternator pushing out too much power. I guess the alternator was the culprit.
08Z06
Oct 24, 2015 05:46 PM
SCMike
Sep 22, 2015 07:34 PM
MrMellor
Sep 7, 2015 10:22 AM
Jaguar Forums Editor
Jaguar Press release
Sep 5, 2015 10:08 AM
Bhoyceltic
US Southwest
Sep 3, 2015 09:11 AM
