Airbag light, code B1342, does module need reprogramming?
Old Sep 18, 2018 | 10:53 PM
San Antonio Joe's Avatar
Talking Airbag light, code B1342, does module need reprogramming?
I have a 2003 XJ8 with a constant airbag light. After doing all of the online suggested fixes, I tood it to Victor's Jaguar in San Antonio. They specialize in Jags and have a very impressive shop!
After scanning the car, he told me the module is bad, code B1342. I've removed the current module, cleaned the pins and connector with electronics spray and made sure there was no corrosion at the grounding points. I still have the light.
The module, HNC9666AD, is readily available online, but I would like some guidance from a Jag owner or mechanic. On the module, there is the part number, and a long number just above a bar code. I've attached a photo of one currently for sale on ebay.
Here's what I need help with:
1. Is the long number above the bar code critical, and needs to be matched with another module, or is that just the serial number for that unit? All of the parts I've seen have the same part number, HNC9666AD, but the other number is different.
2. Will a different module need to be reprogrammed, or can I just replace my module with another one with the same part number?
Thanks in advance for your help.
Joe Wiggins
2003 Jaguar XJ8
Part number HNC9666AD
Old Sep 20, 2018 | 01:57 PM
Highhorse's Avatar
You'll want to bookmark this site.... JagRepair.com - Jaguar Repair Information Resource
Last edited by Highhorse; Sep 20, 2018 at 06:20 PM. Reason: Deleted for incorrect info.
Old Sep 20, 2018 | 02:08 PM
motorcarman's Avatar
B1342
Single Point Sensor module internal fault or module crash record full.
MONITORING CONDITIONS
Switch ignition ON for more than 10 seconds:
POSSIBLE CAUSES
Single Point Sensor module has logged three impact events.
Single Point Sensor module failure.
bob
Old Sep 20, 2018 | 02:09 PM
Jaguar internal ABS control module failure - http://jagrepair.com/images/TSB/Trai...%20Systems.pdf ....and the repair... http://www.jagrepair.com/images/Auto...aul%20Bush.pdf
There are a few threads here on simpler repairs of the ABS to solder the joints where you don't remove the top, just drill a hole and patch afterward.
You are reading the ABS DTC guide. The OP has SRS fault.
Different module.
Old Sep 20, 2018 | 06:21 PM
Highhorse's Avatar
Different module.
Sorry about that Bob, I deleted my response for it.
Old Sep 20, 2018 | 07:12 PM
Thanks for the link to the service manual. I think it will give me a lot of guidance.
As for the code, I was told by a Jaguar repair shop that the code means the SRS module has failed. As far as I know, the car has never been in a wreck. I have ordered a module off of ebay, and will swap them out. I also noticed the part number, HNC9666AD, seems to be replaced by HNC9666AE.
Are you recommending a different course of action other than swapping out the module?
J KF Sze
Oct 12, 2017 02:24 PM
car5car
Mar 19, 2015 09:46 PM
Ngarara
Oct 13, 2013 12:39 PM
WinterJag
May 30, 2012 09:46 PM
David Type S 01
Aug 29, 2010 03:53 PM
