AJ-26 intake cam sprocket damper question.
Old Feb 18, 2016 | 10:28 PM
Addicted2boost's Avatar
Default AJ-26 intake cam sprocket damper question.
So I'm putting my 98 XJR timing chains back on after I had the heads off..... And of course I forgot to put the chains on the left hand intake cam sprocket prior to torquing down the camshaft... Since I really didn't feel like taking the cam back off just to install the chains, I took the intake sprocket off instead. Noticing how the "damper" (??) on front of the intake sprocket is separate, could I invariably just leave that dead weight off of it??? I'm not trying to reinvent the wheel nor am I trying to gain hp, I'm just simply wondering why so much dead weight without any (seemingly to me anyways) functionality is even on there. Has anyone left it off with any adverse effects from it?
Old Feb 18, 2016 | 10:46 PM
sparkenzap's Avatar
They did not put that there to give away metal! The purpose of a damper on a rotating shafts to dampen vibrations. Vibrations are metal flexing! What do you suppose happens to metal bars subject to constant flexing?
Old Feb 18, 2016 | 11:37 PM
Give away metal... Now that's funny!!
I suppose your right about the flexing and vibrations. I just think it was waay overkill in weight. It feels like it weighs a half pound!!
Old Feb 19, 2016 | 08:43 AM
sparkenzap's Avatar
You would have to do some finite analysis to make that determination, and I would have to assume that Jaguar did that.
TexMurphy
Mar 16, 2016 07:40 AM
Gerard Radimaker
Feb 27, 2016 03:05 PM
skubeedoo
Feb 17, 2016 11:44 AM
L80ous
Feb 13, 2016 01:06 AM
L80ous
Feb 13, 2016 12:47 AM
