Alarm went off - door switch?
Old Apr 10, 2011 | 05:45 AM
yeldogt's Avatar
Default Alarm went off - door switch?
I was working outside yesterday and the XJR starts its warning countdown - then the alarm goes off?? I had not moved the car for a few days. I figured that the trunk was not fully closed -- wrong.
After playing with the doors / trunk / hood for a while -- I think the problem is with the front passenger door (RF)
As best as I can figure out the car thinks the door is always open. The other doors will activate the interior lights and then the car goes into the long interior light timeout because it thinks the front passenger door is still open. If I open just the FR door - nothing happens? I am guessing because the car believes it is already open.
Does anyone know how this system works?
I am thinking that maybe the door switch failed -- not sure how the car gets the signal. I am thinking the alarm and lights use the same normally open switch that closes when the door opens.
Obviously ........can't lock the car.
The other possibility is that the circuit is closed when the door is closed and "opens" when the door opens -- in this case it could be the switch or a broken wire someplace or even bad connection.
Old Apr 10, 2011 | 10:06 AM
yeldogt's Avatar
I have been searching around ............looks like the switch is not available seperatly? Not good
Chuck Schexnayder
Sep 18, 2015 03:10 PM
RaceDiagnostics
Sep 13, 2015 02:22 AM
kabs3012
Sep 12, 2015 10:40 AM
kabs3012
US Midwest
Sep 10, 2015 01:17 PM
1964Daimler
Sep 9, 2015 11:28 AM
