Alternative to flush adapter 100-022
Old Jan 30, 2017 | 10:45 AM
Dan R's Avatar
Default Alternative to flush adapter 100-022
I am planning to flush the XJ8 radiator, engine and heater.
The tech bulletin calls for installation of Adapter 100-022 into the radiator drain to back flush it. It is a simple adapter to allow connection of a hose. Any ideas on a substitute? Don't fancy paying $32.99 for one!
Old Jan 30, 2017 | 04:09 PM
andrew lowe's Avatar
You could always pull the drain plug and take it to the local plumbers merchants and see if they can match the thread and put a few pieces together so you can attatch a hose.
Old Jan 31, 2017 | 12:10 PM
Dan R's Avatar
Trouble is that it will be metric and everything here will be inches. Some sizes are interchangeable though.
Old Jan 31, 2017 | 05:22 PM
al_roethlisberger's Avatar
Any idea if this adapter is the same for the X300 radiator?
Old Feb 1, 2017 | 12:46 AM
Dan R's Avatar
The website describing the adapter states "Applications X400"
That doesn't tell me much.
The adapter 100-022 is described in TB 303-11 - V8 XJ/XK Coolant change Model range 97-99.
