Amp/sub install wfactory stereo (XJ8)
Old Jan 11, 2014 | 07:16 PM
Eric Pearce's Avatar
Default This should be VERY simple....
If your Jag has the rear factory sub, Crutchfield sells speaker adapters that will tap right into the factory harness. Run these to the speaker level inputs of an aftermarket amp (in my case an Alpine MRP-M500). Amp install kit, connect right to the battery (very convenient in the boot). Remote turn-on lead to the power antenna via inline splice (also very conveniently in the boot). Mount the amp to your sub box (in my case a Q-logic box with a pair of Polk Audio 12s). Bada Bing, should be crankin! I will let everyone know what it sounds like when it's done. BTW, I have a pair of factory 6x9 Alpine dual-coil subs for sale if you just want to "fix what you got"... One is NOS that I've been running for about 6 months, the other is my original that had surround rot and I replaced the foam surround with a butyl rubber one. Let me know if you are interested!
Old Jan 21, 2014 | 01:29 AM
Zorasmiles's Avatar
Looks like quite a few folks wanting just a little bit bass.
Can we get a few install pictures of those who've completed the project?
Feedback on bass travel to the cab (since the gas tank blocks off a lot and porting through the rear deck might be required to get the bass from point A (trunk) to point B (cabin).
Post those install pics!!
Old Jan 21, 2014 | 01:14 PM
grandell's Avatar
still a work in progress... but it's getting there!
click the pics to go to the whole album
Attached Thumbnails Amp/sub install wfactory stereo (XJ8)-dsc05647_zpsed8c47aa.jpg   Amp/sub install wfactory stereo (XJ8)-dsc05643_zpsfeb67531.jpg   Amp/sub install wfactory stereo (XJ8)-dsc05612_zps764c1820.jpg
Old Jan 21, 2014 | 03:25 PM
Zorasmiles's Avatar
Very clean install! Awesome selection of audio pieces! I'm still loving that subwoofer enclosure!
Thanks for posting up the album!
Old Jan 21, 2014 | 09:20 PM
grandell's Avatar
Credit where it's due, a lot of the inspiration came from EAPJ
Multi-Media
Old Jan 21, 2014 | 10:07 PM
Zorasmiles's Avatar
You're welcome and thanks for giving credit whee credit was due!! Some rob others and pretend it is their own idea.
I will probably keep my initial install simple and sweet, I will post up simple pics of my install.
Old Jan 26, 2014 | 09:04 PM
v12mike's Avatar
Thought I would share what I did with my XJ8 I just got a couple months ago:
I soon realized that the original subwoofer on the rear deck was out of commission. (perished foam surround upon further inspection.) So I decided to install a powered Infinity Basslink sub I'd taken out of another car a few years ago.
With the use of a Line-Out Converter (with remote amp turn-on signal), all the wiring takes place in the trunk. My car has the trunk mounted factory amp, so it was just a matter of splicing the line-in signal for the LOC from one of the speaker wires coming out of the factory amp.
I am far from any sort of serious audiophile, but the sub works great as far as I'm concerned. Eventhough there is no direct porting from the trunk into the cabin, there is more than enough bass that can be heard and felt. I think I read somewhere once that, in this type of installation, the entire trunk cavity becomes a sealed enclosure, and somehow resonates the sound waves through the car structure?
LOC that I used:
Amazon.com: PAC SOEM-T 2-Channel Premium Line-Out Converter with Remote Turn-On Trigger: Automotive Amazon.com: PAC SOEM-T 2-Channel Premium Line-Out Converter with Remote Turn-On Trigger: Automotive
Attached Thumbnails Amp/sub install wfactory stereo (XJ8)-amp.jpg   Amp/sub install wfactory stereo (XJ8)-0030a702-44f3-4358-84ba-6c70fd3d304d.jpg
Old Jun 16, 2016 | 02:34 PM
  #28
harveyleonj's Avatar
Default Wire colors
LOC that I used:
What is the wire color coming out of the amp that you spliced into? I have a 2006 xjr and already bought the loc.
Old Aug 23, 2016 | 01:05 PM
poisonpill's Avatar
Could I just buy a dual voice coil 4ohm subwoofer and splice into the 4 wires that feed into the 6x9 subwoofer (disconnecting it) in the back? I never use the backseat so I was considering putting a subwoofer there or on the floor.
Old Aug 23, 2016 | 05:02 PM
  #30
CharlzO's Avatar
You could, but the power coming from the factory amp to feed the factory sub, might not be as satisfactory as you hope. I'm not sure what the specs are, in all honesty, so I can't speculate further.
Old Aug 23, 2016 | 08:31 PM
  #31
Addicted2boost's Avatar
I have to admit, It's getting old having a nonfunctional 6X9 in the rear deck. I'm alittle too OCD not having anything other than a properly working DVC 6X9 back there. I know for a fact that it's just the speaker and not the amp. This is the 21st century! Can't somebody make these??
Old Sep 1, 2016 | 01:56 AM
  #32
poisonpill's Avatar
Couldn't I just get a small 2 channel amp just in front of the sub to give it a little more power?
Old Sep 1, 2016 | 08:50 AM
  #33
CharlzO's Avatar
Oh certainly could. You might need a level converter if you're using the factory "sub" wiring as a source signal depending on the amp. I've had mixed luck with them, but at least then you would have a dedicated power source that will likely push more than the factory amp would.
Old Sep 1, 2016 | 10:35 PM
  #34
larney's Avatar
Is it the surrounds rotted away?
Old Sep 1, 2016 | 10:43 PM
  #35
larney's Avatar
So question. The 6X9 sub in the rear deck since it's a DVC does it have 4 speaker wires going to it? 2 for left and 2 for right?
Old Sep 2, 2016 | 07:44 AM
  #36
Sean B's Avatar
yes.
Old Sep 2, 2016 | 08:19 PM
  #37
larney's Avatar
So I guess this might seem like a stupid question. Since the DVC speakers are hard to find how hard would it be to mount a second 6X9 woofer back there? I know you'd have to cut a second hole in the rear deck and of course the package tray itself. But since there's two sets of speaker wires back there and if you don't buy some power hungry speaker wouldn't this be an option? Am I missing something?
Old Sep 3, 2016 | 01:47 AM
  #38
Stu 1986's Avatar
I've just typed in "Dual voice coil" on ebay uk and got back many results, but there are 6x9 dual voice coil speakers on US ebay. I don't know how good they'd be or if it's what you need, but I'll post a link anyway.
Dual Voice Coil Speaker - 140 Watts - Ford | eBay
Old Sep 3, 2016 | 04:24 AM
  #39
larney,
You can't install another 6X9 on the other side of the shelf because of the gas tank. If you actually removed the trunk carpeting that covers the gas tank, you'll see what I mean. They actually made an indentation on the top of the tank to accomidate the one 6X9.
Stu,
As long as that speaker is an 8 ohm range and it's shallow enough to install, then it should be ok. I did not see any technical references on that particular speaker other than it fits 1960-1962 fords. Not very specific at all.
Old Sep 3, 2016 | 04:49 AM
  #40
Stu 1986's Avatar
Originally Posted by Addicted2boost
Stu,
Just trying to help, I'm sure the information is easily obtainable from the seller.
