Android HU installed in my XJR
Old Apr 1, 2021 | 07:14 AM
Ash.Bez's Avatar
Originally Posted by Amphicar770
About 10 years ago I replaced the factory Navi HU with a JVC single din. The JVC was a big improvement but has also become dated.
Today I installed a Joying android unit with a 6.x inch screen. I now have a modern HU with bluetooth, 4G wireless, Waze, Sirius app, etc. I skipped the rear camera.
Install was not to bad. I was able to toss the access steering controller as this is built in. Quite pleased with the results.
here is a link to the unit itself.
https://a.aliexpress.com/_mPqo3DT
Did you manage to get this working with the factory steering wheel controls? this is my next task.
Old Apr 1, 2021 | 09:19 PM
Amphicar770's Avatar
Yes, it works with the steering wheel controls. The sw wire (or may be 2 wires) from the HU tapped directly into a wire on the Jag harness. Unfortunately, I do not remember which wire although pretty sure it was same one that the since removed PAC tapped into.
Old Apr 1, 2021 | 09:23 PM
Btw, it continues to work great.
great. Only issue I have had is one which I experienced in a similar unit, in another vehicle, although only one time on each. The GPS was drifting by a few yards. The fix was as simple as power cycling the unit.
Old Apr 2, 2021 | 04:02 AM
Highhorse's Avatar
This detailed Word Doc on steering controls was provided by Forcedair1 (Reinaldo) last Nov....
Old Apr 2, 2021 | 04:43 AM
Ash.Bez's Avatar
That’s good news, I had doubts that I would need to get a canbus unit and seeing as I couldn’t find a harness I was doubting that I’d find a canbus too. I’ll give it a try this weekend and let you know how it goes.
Old Apr 2, 2021 | 04:56 AM
Ash.Bez's Avatar
Old Apr 4, 2021 | 11:24 AM
Ash.Bez's Avatar
All sorted, simply connected the KEY1 wire to the steering wheel wire and voila. Nice and easy. Got the front facing camera and microphone installed too. Just waiting on a relay for the rear camera. Took it out for a run today and the head unit worked flawlessly.
Old Apr 26, 2021 | 07:10 PM
  #28
5 months later and I remain quite pleased with the Chinesium HU. I did discover one quirk today.
There really is no "off" button. You can reboot or go into standby mode. Not a big deal except ...
I rarely go through a commercial car wash. Today, the XJR was covered in pollen so I was going to run through the touch less car wash. Well, antenna raises when HU is on. Since you can't turn off the HU, there is no way to lower the antenna short of turning off the ignition.
I imagine this is a common issue with these. Perhaps there is an app to raise/lower the antenna. Alternatively, I may need to put a switch in line. For now, I will just avoid the carwash.
Old Apr 27, 2021 | 06:51 PM
Highhorse's Avatar
I hated the antenna, so I bypassed it with this....https://www.jaguarforums.com/forum/x...ve-one-103359/
I don't know if its available anymore, but its an option for you.
Old May 24, 2021 | 05:47 PM
  #30
To address the antenna issue, I just wired a Google switch into the switched wire at the antenna. Now, should I need to lower antenna with engine running, I just open the trunk and flip it.
I almost never go through car wash so trunk location works for me. Alternatively, you could Put switch closer to the dash.
it is the green/black wire at the antenna.
Old May 24, 2021 | 06:48 PM
  #31
Highhorse's Avatar
You could of done that from behind your head unit (not that you still can't) using the antenna activation there and mounted say in the ashtray area.. This way you can stay in your seat and do it.
Old May 24, 2021 | 06:55 PM
  #32
King Charles's Avatar
I just pulled the ant.fuse lol.
Old May 24, 2021 | 08:25 PM
  #33
Highhorse's Avatar
In my link in post 29 I just unplugged it.
Old May 26, 2021 | 05:15 PM
  #34
Certainly true but, I did not feel like pulling the HU back out. For the 2x a year that I might need to lower the antenna, this serves the purpose.
Even when you turn off the car, the android HU waits a few minutes before signalling antenna to lower. Pulling fuse only helps once it is already lowered.
Old Jun 20, 2021 | 05:52 PM
  #35
ejbevan's Avatar
@King Charles awesome install! What fascia did you use with that to fit the double din unit in?
J
Originally Posted by King Charles
My Kenwood DPX501BT does everything w/o a screen, BT hands free calling w/ mic installed by sun visor,phone & WAZE navigation syncs over audio system when in use. USB, seamless Sirius XM radio interface in the head unit with or w/o remote. Most importantly, I can go back to OEM if I choose, as it didn't have to hack up the dash internals for install. It's about 6 years old now but still offers everything I want in a cohesive package.
Old Jun 20, 2021 | 06:11 PM
  #36
J
Not sure it was professionally installed years ago.
Old Jun 24, 2021 | 06:53 PM
  #37
grandell's Avatar
It will be the usual single din fascia adaptor, just modified to fit the double din. A quick google or ebay search for X308 facia adaptor should find it
Old Dec 15, 2022 | 09:20 PM
  #38
3 years later and it is still going strong. Recently it could no longer connect to any Google services. That required a firmware update via USB stick. Thus, I had to pull it out to get to the USB port. Other than that inconvenience, all well.
Old Dec 16, 2022 | 01:52 AM
  #39
Highhorse's Avatar
You could put a USB lead over to the glove box so you wouldn't have to remove the unit.
Old Dec 21, 2022 | 07:58 AM
  #40
Yes, I did just that when I pulled it out this time. Fortunately, removal and replacement was only a 10 minute job (6 screws).
