Any special tools required to replace front rotors?
Old Mar 18, 2010 | 02:48 PM
newuser's Avatar
Default Any special tools required to replace front rotors?
Sears is charging about $70 to recondition the rotor (not sure if they said per rotor) and that's only if they're not to bad. But I think I can get new rotors elsewhere for about the same price and just install them mysef. I replaced them once on my Camaro SS with standard sockets and allen wrench but not sure if these cars are much different. Thanks in advance.
Old Mar 18, 2010 | 03:43 PM
Thewaxmania's Avatar
7mm allen drivers to get the calipers off the carriers and 22mm socket to get the carrier bolts off. They are torqued to about 100 ft lbs so you might have to wrestle with them or use an impact gun. Otherwise its a pretty simple operation. Rotors are held on by the wheel studs so there aren't any fasteners for those. Good luck.
Old Mar 18, 2010 | 05:19 PM
newuser's Avatar
Thanks for the info. seems pretty simple.
Old Mar 20, 2010 | 02:46 PM
Stu 1986's Avatar
Ha Ha! Thats where the danger lies! My Caliper hanger bolts were stuck fast, I went through 2 breaker bars, a can of gas for the heat gun and they still wouldn't budge! In the end it took 3 Bus mechanics 1/2 at the depot to get them off!
What I'm saying is: Be prepared!
Old Mar 20, 2010 | 03:53 PM
Gus's Avatar
Gus
That is why a good impact wrench, compressor and a can of PB spray is part of my arsenal when taking on a project like this. A trick I learned is to tighten then loosen and do it again if it does not work the first time.
Old Mar 20, 2010 | 04:37 PM
JWT's Avatar
JWT
I was not as smart as Gus. Did mine a couple of years ago, I got the carrier bolts off, but damn near got a hernia at the same time!
Old Mar 20, 2010 | 05:12 PM
Gus's Avatar
Gus
If it will make you feel any better I had the same problem when I did my 95xj6. I know better now!
philwarner
Dec 6, 2021 07:13 AM
Paradigm
Jun 15, 2019 05:59 AM
martybmw
Aug 31, 2015 10:15 PM
ronald4313jm
Aug 31, 2015 07:58 AM
souldoubt
Aug 25, 2015 08:15 PM
