Anyone have schematics for rear fuse box, lights, trailer connection for 2002 XJR >
Old Nov 5, 2014 | 07:25 PM
beady's Avatar
Default Anyone have schematics for rear fuse box, lights, trailer connection for 2002 XJR >
that they wouldn’t mind sharing with me?
I have the schematics for the ’98 XJ Series, but the wiring colors are different. It would save me a bit of hassle trying to figure which wires are which if I had a schematic that was correct for my year.
Thanks,
Mike
Old Nov 5, 2014 | 09:51 PM
avt007's Avatar
Try this.
File Type: pdf
Old Nov 5, 2014 | 10:42 PM
Mark SF's Avatar
The problem I encountered is that the jag has separate stop and indicator lights, and your trailer won't, so you need some way of combining those connections on the jag trailer connector. At this point I decided to use a Curt 56146 module, and at that point you might as well splice the inputs to the wires to the lights. Good news : on the jag, the battery is pretty handy for the supply connector.
Old Nov 6, 2014 | 05:06 AM
beady's Avatar
Thanks AVT.
Mark, going to run my low brake lights and tails from the trailer circuits, not actually use a trailer, thanks for the info though.
Mike
hafren
Aug 30, 2023 03:42 PM
aholbro1
Sep 24, 2019 12:07 AM
chipnping
Mar 8, 2016 10:33 PM
montypeek
Sep 6, 2015 04:57 PM
roumor
Aug 28, 2015 01:02 PM
