Auto Headlight Problem
Old Jan 28, 2010 | 07:14 PM
burmaz's Avatar
The review mirror has a sensor in it for the auto headlights. That could be your problem?
Old Jan 29, 2010 | 03:07 PM
Sarc's Avatar
Good call Burmaz
Thats probably it. I have done a rear view mirror replacement before and the wiring for the headlight sensor is very fine and fiddly
Old Feb 20, 2010 | 02:24 PM
SuperSport's Avatar
does anyone have a picture of the plug that goes into the mirror? I got a mirror with the wires out, so I need to figure out the sequence for reconnection. I've got yellow, green, black, white, grey, but don't know the sequence to plug them back into the yellow plug. My car has the Auto Dim and Auto Headlight features.
Thank you in advance.
Old Feb 20, 2010 | 04:16 PM
test point's Avatar
The best mirror thread ever is here compliments of Mr. GordoCatCar:
https://www.jaguarforums.com/forum/s...ad.php?t=17719
Old Feb 20, 2010 | 05:02 PM
SuperSport's Avatar
Thank you test point. I did run into that thread when I was doing my search, but unfortunately, it does not show the wiring at the plug on the mirror. There is one photo of my mirror, but the plug was out of the photo. I need the order in which the colors go on a 5 wire mirror with Auto Headlights.
Thank you again.
Old Feb 20, 2010 | 07:39 PM
Sarc's Avatar
@ SuperSport
I have a mirror off my '00 XJR lying in my garage and it has the correct connectors and hasn't been messed about with (only replaced it because the autodim failed) Unfortunately (on many levels) I'm currently in Taiwan :-(
I'll be back mid next week and will check this thread again to see if you've got your answer..... if not I'll take you a pic mate
Old Feb 21, 2010 | 02:43 AM
SuperSport's Avatar
Thank you Sarc,
If I don't hear from anyone else, I would Greatly appreciate that.
Old Feb 25, 2010 | 01:04 AM
Sarc's Avatar
@ Supersport
Dont' know if you found the info already, but here's a few pics of the mirror wiring....
Taking the locator pin as 6 o'clock, as working clockwise, the colours are : Grey, white, yellow, green, red, blue brown, black
With the locator pin on the left, the colours are red, purple, blue, going from left to right
Wolfy
May 28, 2024 08:06 AM
afterburner1
Dec 16, 2015 12:12 AM
mcdutch
Sep 4, 2015 03:38 AM
laserguy
Sep 3, 2015 02:02 PM
King Charles
Sep 3, 2015 12:40 AM
