auxiliary water pump
my auxiliary water pump has begun making an awful noise while I have the ac on is this supposed to be on when the heater is not on or does it run with the ac too. and do i need to replace it or is there something else going on here I dont know about
Cool....that pump should run all the time except with a low coolant temp or panel off mode. So are you sure its the auxiliary pump? It sounds more like the A/C clutch when its engaged on the A/C pump.
