Back lights in car
Old Oct 28, 2017 | 08:16 AM
jrb53's Avatar
Question Back lights in car
Hi all new problem 2000 xj8 my car this time. I had to do a hard rest as my drivers window was not working works now, problem is all the back lights dash center console everything works , but no back lights j gate lights up have checked fuses left hand kick board. I can see a bulb going out but all of them at the same time is strange what a I missing any thoughts would be appreciated thanks jrb53
Old Oct 28, 2017 | 03:07 PM
Highhorse's Avatar
Have you pulled the panel to check'em? On cars this age, don't discount what a minor surge could do to it.
Old Oct 28, 2017 | 04:03 PM
Lady Penelope's Avatar
I believe there is a Jaguar TSB covering this item for the X308 series
http://www.jagrepair.com/images/TSB/XJ/413-03.pdf
Complete list as of updated period for 1998 - 2003
http://www.jagrepair.com/XJTSB.htm
Old Oct 28, 2017 | 06:43 PM
Does the dimmer override work to laminate the Center Control Switch Park ?
Additional TSB to consider :
http://www.jagrepair.com/images/TSB/...%20failure.pdf
Editing , wiring schematic
Old Oct 29, 2017 | 07:37 AM
jrb53's Avatar
the dimmer works fine can dim out mileage will pull panel to check bulbs thanks
