Battery Not Charging
Old May 17, 2011 | 08:24 PM
sparkenzap's Avatar
You MIGHT just have overvoltaged a module. Some battery chargers are prone to do that on high settings if you have a low load battery situation like an open cell. Turning the key to on WAS NOT a good strategy. On the other hand, with luck, you have just not tightened the clamps good. If they are tight, I would try unhooking the battery again, then retry.
BTW, why were you charging the battery anyway? You might just have a dead battery.
Old May 17, 2011 | 08:25 PM
Sinister 1's Avatar
Does anything else in the car work or is it totally dead?
Without more details a wild guess is...
If everything but the starter works, my first guess is an open circuit in the main positive cable or a bad ground strap somewhere between the battery and engine block. The reason I say that is the not charging message coming and going might have been an indication of a failing circuit.
Forcedair1
Sep 8, 2025 01:57 PM
Rivguy
Nov 13, 2022 02:55 AM
gold59
US Lower Atlantic
Sep 16, 2015 06:27 AM
Charlene n John
Sep 14, 2015 10:08 AM
jaguarbill
Sep 5, 2015 11:43 AM
