Brake light Flashes and turns off
Old Oct 8, 2020 | 11:24 AM
Mansehra's Avatar
Arrow Brake light Flashes and turns off
Hi All,
I am new to the forum and ownership of an 2002 XJ8 Sport. My driver side tail light flashes and turns off when the brake pedal is pressed. I have swapped the bulbs from left to right just to check if it might be an amperage issue and even happens with the bulbs swapped. I have read a lot about the SLCM is the major cause for this happening and I reached out to an eBay lab that fixes the SLCM's and they responded that it is probably not an SLCM issue and could be a ground. I went over another vlog that shed some light on the wiring diagram and according to that, the left and the right have the same ground. Now I am new to this car and have no idea what could be a possible problem. If anyone can shed some light I will be grateful..
Old Oct 9, 2020 | 09:12 AM
Welcome to the forums Mansehra,
I've moved your question from the US Northeast Region forum to X308 forum. Members here with the same model will be able to help.
Old Oct 9, 2020 | 10:44 AM
avern1's Avatar
Unplug the connector going to the light fixture and exam the prongs on the connector. The far outboard prong is the ground. Is it showing distortion, overheating or any damage? The one small connector tends to overheat since it provides ground for all of the lamps. If it shows distortion you can gently form it back in shape to match the other prongs.
heartmyjag
Jun 6, 2016 09:14 PM
Airportrat
E type ( XK-E )
May 22, 2015 08:50 PM
MJG
Jan 31, 2013 05:55 AM
MLRocafella85
Jun 25, 2011 05:18 AM
