brakes advice
Old Oct 30, 2008 | 11:32 AM
wdmoreton's Avatar
Default brakes advice
The brakes on my '99 XJR have not felt right since I bought it a few months ago. Im finally going to get around to inspecting them and replacing anything that needs it. The cost of genuine Jag parts (rotors) is ridiculous in my opinion ($800 for a pair of front rotors ?) I have seen some Brembo rotors for much less and they are a name I know. Any reason not to use these cheaper rotors that anyone is aware of ?
For pads I was going to use RedStuff. Anyone know of any reason not to, or can recommend an alternative ?
Thanks in advance.......
Old Oct 30, 2008 | 02:47 PM
ken@britishparts.com's Avatar
Default RE: brakes advice
Brembo makes the factory cross drilled pads. I've heard lots of good things about the Redstuff pads. Go for it!
Old Oct 30, 2008 | 11:01 PM
wdmoreton's Avatar
Many thanks Ken. I haven't had time to research this properly yet, but I seem to remember there being an "ABS ring" or something required ? Is that something I have to check the rotors have ? Im probably completely wrong.
Thanks again
Old Oct 31, 2008 | 10:38 AM
No. The ABS ring must be removed to replace the front wheel bearings. Not requiered in a rotor change.
PMKimpton
Aug 3, 2019 08:22 PM
wvanepps
Oct 4, 2015 10:01 AM
jdzubas
Oct 4, 2015 09:14 AM
Pluckie
Oct 3, 2015 07:57 AM
Jefro
Sep 15, 2015 01:44 PM
