Here's the site.... https://www.superbrightleds.com/ ...and yes they will have your car. Be sure to prompt, See All Compatible to get the complete list.
If you are doing the dash, be sure to use the CAN BUS ones so the computer will recognize them or you won't be able to dim them and they'll be bright as hell.
Here's a screen shot of my order from March (I did not use them all), as cheap as these are, it was easier to buy variety and find which ones I liked as I applied them. Reason being, colored lenses effect colored LED's differently. I'm not home, I'm in Tallahassee on a contract job or I'd get you what I used and where....
Thanks only doing the 3rd brake lights, LEDS in the dash etc. I find too bright. I have some wedges etc. left over from doing overhead console,puddle lamps & rear vanities. Hopefully get to the brake light tomm.
Tackling this in the morning, I have some white LEDs leftover that will work. I will test them to the rest of the incandescent rear lighting & see if it's uniform brightness.
Ok so I found a new OEM unit but of course SDZ has been discontinued, the closest I could get is AGD/Oatmeal. Oatmeal & cashmere are close when looking @ separately but side by side it draws my eye. I have enough SDZ seat colorant left over that matches perfect. I don't have a functioning air brush & I think w/ the seat colorant being so thick would render prominent stroke marks, so I will try & find a matching spray paint for plastics locally. If no luck w/ the paint quest I will use the seat color.
AGD-SDZ Comparison
I do have a great shape used SDZ cover from CK but the lure of installing a fresh/new unit is strong lol.
Here's new unit w/ used cover, hmm that does look great w/ no hassle of painting.
To be continued,
