Broken Vacuum Hose
Old Mar 28, 2014 | 10:53 AM
TheHilds's Avatar
Default Broken Vacuum Hose
I have a broken vacuum hose on my 98 Vanden Plas that runs from the driver side valve cover, under the fuel rail and into a "T" connection right near the throttle body. Do I need to remove the TB in order to get to that connection or does anyone have another suggestion?
Old Mar 28, 2014 | 12:35 PM
Probesport's Avatar
No, you can get to it but its tight. Attach new one to old so you can pull it through.
Old Mar 28, 2014 | 12:50 PM
TheHilds's Avatar
Thank you. Already pulled the TB just so I can inspect the rest of the line and I am going to replace it all while i'm here. Any other hoses I should look for to replace while im in here?
Old Mar 28, 2014 | 12:53 PM
Probesport's Avatar
All of the convoluted tubing hoses should be checked for cracks and leaks. I ended up replacing a bulk of mine with silicone hose.
When you remove them, fill with water and check for leaks its the easiest way.
Old Nov 3, 2022 | 08:09 PM
schoeman's Avatar
Default What is the part number to the broken line
Mine broke too! Can you tell me the part number or name so I can get a new one?
Pristine97XK8Convertible
Mar 5, 2025 10:32 AM
Justinb
E type ( XK-E )
Jun 21, 2023 05:29 PM
richard bowles
Jun 10, 2023 12:24 AM
04Xjrsteve
May 7, 2019 04:06 PM
thedugger1
Sep 26, 2015 10:27 PM
