Burning Issues!
Old Dec 27, 2010 | 07:54 PM
sparkenzap's Avatar
Stu:
This ain't rocket science. Get a bright light, a mirror and some rags and have a look. It is PROBABLY either the water pump (it leaks around the shaft seal) and you will see coolant below it, a cracked "riser", the plastic thing that the radiator hose connects towith a cap at the front of the engine (known to crack and leak, therefore an aluminum replacement available), or the plastic crossover pipe just in front of the aforementioned riser.
Good luck!
99xk8guy
May 28, 2024 09:36 PM
ZJag
26
Sep 5, 2016 03:33 PM
perfectson
Nov 1, 2015 10:46 AM
powerhouse
Sep 9, 2015 08:08 PM
