Burnt fuel pump wiring harness connector
Subscribe
Nov 23, 2009 | 09:59 PM
In the middle of replacing the fuel pump. Once inside I found the wiring harness connector at the fuel pump crumbled when I was unplugging it. The positive wire is burnt at the metal pin connector. The new fuel pump has a 4 inch pigtail connector that plugs into the fuel pump and the wiring harness plugs into the pigtail.
Can I splice this new pigtail directly into the existing wiring harness?
Is it necessary to replace the entire inside the tank harness?
TIA,
Pat
Reply 0
Nov 23, 2009 | 10:15 PM
No, it's not necessary to change the interior harness in the tank. Most likely the burnt offerings on your wires had to do with a bad fuel pump or a bad ground. Check your ground when you hook up the wires and new fuel pump. That could be a dangerous situation for anything having to do with fuel.
And, yes, you can splice directly onto the existing wiring harness...that's what the pigtail is for.
Reply 0
Subscribe
Currently Active Users (1)
