A/C Recharge Low Pressure Port
Old Aug 29, 2017 | 10:44 PM
edmond1138's Avatar
Default A/C Recharge Low Pressure Port
I cannot locate my A/C Recharge Low Pressure Port in my 2005 Jaguar XJR. I have found two nipples that look like they might be them, but the larger one that looks like it might be the low pressure has an O.D. of 15 mm and will not accept the recharge canister connector.
I've included photo with the caps off.
Any one with an XJR that knows where they are, or if these are them, what type of recharge system to use?
Attached Thumbnails A/C Recharge Low Pressure Port-img_4845_small.jpg
Old Aug 29, 2017 | 10:54 PM
Daim's Avatar
They are them but you are also in the wrong forum section
Old Aug 31, 2017 | 10:59 AM
edmond1138's Avatar
Thanks, I was able to charge the A/C. Which forum do you think I should be in?
Old Aug 31, 2017 | 11:07 AM
Samilcar's Avatar
X350 & X358 2004-2009.
This is the X308 1997-2003 section.
