Cam Chain Tensioner...
Old Mar 26, 2009 | 02:18 PM
Morgai1's Avatar
Smile Cam Chain Tensioner
Hi SportyandMisty
If you want to have total peace of mind and many many hastle free enjoyable miles in your XJ8, the best thing to do is have the lot done in one go.
Firstly, there can sometimes be NO pre-warning that the tensioners are on the brink of eating your engine for breakfast, not until there is one hell of a BANG!
There is no point in replacing just the top (secondary) tensioners, as the cost of the primary tensioners is very low, plus, whilst the engine is partially stripped, it makes financial sense to have the whole lot done at once.
DO NOT listen to those people who suggest that you don't need to change the chains, guides, gaskets as the frontal part of the engine will need to be removed, along with the sump.
Chains will stretch over time, the guides can crack (the new versions are alot stronger)
A proper garage will replace the following:
Primary Tensioners
Secondary Tensioners
New Shorter bolts for the Tensioners
Chain Guides
All Chains
Valve cover Gaskets x2
Sump Gasket
Spark plug (binocular) gaskets
Frontal Engine cover gasket
New Oil
New Oil filter
I had my XJ8 LWB done recently, and this was completed by my local Jag specialist.
Don't expect much change from circa 1,300 pounds (GBP)
I was lucky (VERY LUCKY) I have attached some photos for your reference.
The tensioners had totally broken apart (skies) and my Jag specialist recovered the broken tensioners in the SUMP!!!
Attached Thumbnails Cam Chain Tensioner...-old-guides_chains_sprokets_tensioners.jpg   Cam Chain Tensioner...-close-up-sump-broken-plastic-sat-gunked-up-engine-oil.jpg   Cam Chain Tensioner...-sump-broken-pieces-plastic-tensioner.jpg
Old Mar 26, 2009 | 02:23 PM
SuperSport's Avatar
Now those are some scary pictures. You were fortunate indeed!
Old Mar 27, 2009 | 06:08 AM
Morgai1's Avatar
Talking Tensioners
You're not wrong!
The Jag specialist could not believe what he found, so much so that he asked me to choose his lottery numbers due to the fact that I am now known at this garage as "Mr Lucky"
mikiep
Dec 20, 2019 07:37 PM
Jässe in Pälkäne
Oct 2, 2015 05:38 AM
jonahjob
Oct 1, 2015 07:54 AM
JAMES1944
Sep 29, 2015 11:58 AM
