carrier bearing replacement
I am looking for complete info on how to replace the carrier bearing on a 97 vdp.Do I have to pull the complete driveshaft out or can I separate de back from the front?Thanks for the help.
There are plenty of 'write-ups' on the rear wheel bearing replacement procedure.
I leave the halfshaft in situ in tilt the hub for access to the seals/bearings.
You can use wood blocks to support the hub to drift the races out of the hub assy.
I use a transmission jack with the car on a lift but it can be done with jack stands.
Sometimes the splined shaft will NOT release and then removal of the halfshaft complete can be pressed out with a shop press.
Disconnecting the handbrake cable and 'fishing' it through the pinion end support plate will make it easier to move the hub around.
bob gauff
bob gauff
RoyLittle0
May 25, 2023 02:38 AM
