CEL Stall
Old Oct 21, 2010 | 12:10 PM
tesla4all's Avatar
Default CEL Stall
Just gonna throw this up in the event someone can give me some suggestions while I search previous post. CEL come on this morning. I make a hard corner while accelerating on the way home last evening. Related?...I don't know. Codes this AM...P1384...P1637... One according to my brief research is variable timing sensor relates (bank 1 I think)..The other is throttle body related. Stalls. crank..then will idle then any change in rpm leads to stall. Flushed all TB connectors, MAF sensor, VT sensor connectors. How to determine is vt sensor is bad? Throttle body humming...Yes, I know, I SHOULD be familiar with this being normal or not. As always...thanks in advance for your input...Oh...after I cleaned all connectors the CEL went out but still stalls..
Old Oct 21, 2010 | 02:06 PM
tesla4all's Avatar
small update here....disconnected battery to reset codes...car started normally, then I assume after reading all sensor input went back to low idle and stall. took car out for a ride after cranking a couple of times, slid it into gear and and it drove normally even though CEL light is back on...
Old Oct 22, 2010 | 12:35 PM
tesla4all's Avatar
So, car sat overnite, this morning, started normally, drove fine. Went by AZ had codes read and deleted all systems go!...I will NOT be "gunning" ole girl again.
kingdom worker
Nov 14, 2020 03:47 PM
bdboyle
Sep 16, 2019 05:58 PM
RSpi
Mar 21, 2016 12:02 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
