Changing Antifreeze
Old Oct 26, 2007 | 01:15 AM
dougs02's Avatar
Default Changing Antifreeze
Just changed the antifreeze on my '02 XJ8. Found the drain plug OK, but the refilling it took only about 5 quarts of straight antifreeze. I sucked some out with a squeeze bulb-type tool and added water (after running the engine and cooling it off) to get about a 50-50 mix with my tester.
I must have missed something about draining all the coolant out. The car care owner's manual shows something like 10+ quarts capacity.
If I missed draining something, can someone tell me what it is? Thanks......Doug
Old Oct 26, 2007 | 08:41 AM
ken@britishparts.com's Avatar
Default RE: Changing Antifreeze
Probably some left in the hearter core and low spots through out the system. Did you let it drain naturally or did you push the rest out with water pressure?
Old Oct 26, 2007 | 10:16 AM
dougs02's Avatar
I just let it drain naturally. The antifreeze looked so clean and fresh when I drained it, that I did not flush the system. I used long-life antifreeze as called for by the car care manual. Next time I will flush the system. Thanks for the reply....Doug
ejjbee
Jan 26, 2019 11:53 AM
Scarecrow
Mar 28, 2016 03:17 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
Gerard Radimaker
Sep 13, 2015 10:33 AM
kevo
Sep 8, 2015 09:45 AM
