Cheap Cam Timing Tools
Old Oct 1, 2017 | 11:24 AM
Doug Dooren's Avatar
Default Cheap Cam Timing Tools
Just a warning if you use one of these tool kits. JCNA's tool program has everything for loan except the cam locking bars, so I purchased the kit pictured here for about $45 delivered. Everything worked fine until I went to tension the chains when I noticed some cam rotation. It turned out the bosses on the bars were too long to totally lock the cams down, allowing a few degrees of rotation. I simply ground these down to .600" (from the underside of the bar to the bottom of the boss) - this got everything locked down properly. Recommend you check this measurement before disconnecting the timing gear if you use this tool.
Old Oct 3, 2017 | 02:44 AM
Einhead's Avatar
What would be the correct measurement/height on the studs in order for the tool to firmly hold on to the cams?
/E
Old Oct 3, 2017 | 06:32 PM
nickhand's Avatar
Thanks for the tip. I'm waiting on this tool to replace chains etc on my XK8
Old Oct 4, 2017 | 06:51 PM
E - I'm not certain I understand your question. The vertical distance from the bottom of the bar/flats on the cams to the plane of the head surface the tool bolts to is .600". That's the length of the bosses on the tool I mentioned above - I had to remove 15 thousandths (.015") from the bosses to get the tool to work properly. Hope that answers your question.
Old Oct 5, 2017 | 05:53 AM
Einhead's Avatar
Thank you Doug, it was what i meant.. now i can doublecheck the measurement on my own tool. :-)
