cheap dead pedal for a 2001 XJR
Old Feb 23, 2011 | 10:06 PM
pdog2000's Avatar
Default cheap dead pedal for a 2001 XJR
anyone know where i can get a cheap dead pedal...i just can't rationalize paying $175 for one from arden or mina...any other alternatives...i was thinking of even putting a block of wood there as my jag doesn't have a dead pedal
Old Feb 23, 2011 | 10:46 PM
plums's Avatar
How about a block of wood .... rosewood ... topped with a sheet of brass
edit: maybe go down to the trophy store and pick up a wall plaque of the right size. they can even engrave whatever you like on it.
Old Feb 23, 2011 | 11:04 PM
luc's Avatar
luc
My 01XJR do have a dead pedal molded in the carpet with rubber/plastic covering.
Are you saying that your's don't or you want to bring it higher?
Old Feb 24, 2011 | 12:16 PM
X308_XJR's Avatar
Yeah, I would like to have one also, to raise the height of what's there a bit. If you find a reasonable solution, but sure to let us know. I think I paid around $60 for a full set of gas, brake, clutch, and dead pedal for my bimmer. Wish it was that easy with jag. Hmmm.... wonder if one for some bimmer model could be made to work?
Old Feb 24, 2011 | 03:41 PM
benebob's Avatar
ud
Only dead pedal I want is a clutch on mine.
Old Feb 24, 2011 | 08:46 PM
pdog2000's Avatar
mine doesn't have a dead pedal at all...just the carpet...
toronadomike
Jan 22, 2026 10:13 PM
Ipc838
Sep 13, 2015 03:27 PM
skadmiri1
Sep 9, 2015 11:27 AM
Kmw
Sep 8, 2015 04:52 PM
hen555
Sep 7, 2015 11:13 PM
