Check rear lights amber warning on dash
Old Jul 25, 2017 | 01:13 AM
user 652867429824's Avatar
Banned
Default Check rear lights amber warning on dash
I have gotten this before but went away for sometime, quit a long time. Anyhow it started up for the past 2 or 3 days, with it coming up more frequent today. Back lights and brake lights work fine.
When I got home hooked up my scan tool and the code I have is C1300/ ABS pump motor CKT failure. So question is, could this be related (hopefully) to the solder connections in the module? I still have to check to see it the harness connector id clean and not loose, will do that on a cooler day(been hotty hot my way lately and a/c in garage is not working )
Thanks for any suggestions
Old Jul 25, 2017 | 05:17 AM
ericjansen's Avatar
Number one suspect is a low voltage from the battery,
Number two is a bad connection from the bulb in the bulb holder,
Number three is a bad bulb,
Number four is a bad brake switch.
I have been hunting this 2 years ago, inspected all bulbs several times.
Finally found a internally melted bulb, still fully functioning, but triggering a short and the message from time to time.
Replacing solved the issue.
Old Jul 25, 2017 | 07:02 AM
King Charles's Avatar
I had a similar to Eric's scenario, had fully functioning bulbs w/ "Check Rear Lights Message". Upon inspection one bulb was melting & the receptacle looked as if it had been pelted w/ salt water or something as corrosive.
Old Jul 25, 2017 | 07:34 AM
Banned
Thanks guys, forgot about checking the bulbs and the connectors. should have been the first thing to think of DUH Me. will check them this week end when it cools down some
Old Jul 25, 2017 | 07:35 AM
If like mine, be prepared to wrestle it with pliers & maybe curse a bit lol.
Also already 94 FH @ 8 am here lol. Want to wash my car but the humidity's like "It can wait Charles" lol.
Old Jul 25, 2017 | 07:29 PM
RJ237's Avatar
Include the license plate lights, often overlooked.
Old Jul 26, 2017 | 12:34 AM
Banned
Come to realize, maybe it's not just me. But it seems as a new owner of the X308 we sometime forget to check the basics first, we seem to read too much into things and right off think the worse. Maybe that's because of the older Jag I have. Like the old saying for most things start and KISS (keep it simple stupid) Hopefully will get to it this weekend, so far it is to cool off somewhat. Then start pulling and checking bulb and the connectors, guess clean them up a bit and put some bulb grease/dielectric grease on them
Old Jul 26, 2017 | 02:38 AM
ericjansen's Avatar
...as a new owner of the X308 we sometime forget to check the basics first, we seem to read too much into things and right off think the worse...
Yeah, I found that reading too much about all kind of problems on this forum doesn't help in having confidence in these cars ... just riding and enjoying them works way better ...
By the way, I don't think the license plate lighting is part of the message center, but it is never wrong to check them too while you are there.
Old Jul 26, 2017 | 06:27 AM
Indeed, many a time I've found myself scouring this forum & fretting potential causes & it was a fuse or equally simple fix lol.
Old Jul 26, 2017 | 08:44 AM
RJ237's Avatar
It may not, but on my X300 it was, so it's worth including.
