Clunk from engine
Old Dec 7, 2016 | 04:57 PM
omgimali's Avatar
Default Clunk from engine
This has never happened before but my xj8 thunks/clunks every min or 2 later just out of no where (when started).
Is this normal?
Old Dec 7, 2016 | 09:03 PM
JTsmks's Avatar
I gotta ask, do you have the uprated tensioners in it?
Old Dec 8, 2016 | 05:00 AM
Addicted2boost's Avatar
I think I know what you mean. Is there a loud popping sound?? If so, it's just the engine warming up. I don't know why only certain 308's do this other than metal expansion. It's probably the exhaust manifolds and the manifold gasket on the head. Is it normal? Not really, but it's not hurting anything.
Old Dec 8, 2016 | 03:17 PM
omgimali's Avatar
Nope, the car has 78k miles, thinking of upgrading metal tensioners and chains as well as the guides.
Old Dec 8, 2016 | 03:18 PM
omgimali's Avatar
Thanks man it got me worried but it has just started to happen like this.
Old Dec 9, 2016 | 07:01 PM
Vector's Avatar
Is this normal?
A normal "clunk?" No, not at all!
Unless it only happens going over bumps, then you need to check the sway bar links and bushings and front upper shock bushings.
Vector
Old Dec 9, 2016 | 07:28 PM
omgimali's Avatar
Vector
You're scaring me man. Gotta check this out.
Old Dec 9, 2016 | 07:31 PM
omgimali's Avatar
its that same noise at 2:04
Old Dec 9, 2016 | 08:20 PM
Thang Nguyen's Avatar
I never heard the sound of this engine before, watch and hear the sound on video I can't tell any difference, put the handle end of a long screw driver to your ear and the tip of it to various point of the engine to pinpoint where the sound came frome.
Old Dec 9, 2016 | 09:32 PM
xjay8's Avatar
Frankly, sounds completely normal to me ;o)
Valve rustling, injector ticks and the regular clicking of the
solenoids that operate about every couple of minutes to feed
oil into the VVT's (Variable valve Timing).
These are only found on 4.0 ltr NA engines, not super charged ones.
Nothing sounded out of place to me ;o)
Old Dec 10, 2016 | 02:41 AM
ericjansen's Avatar
I hesitated to post it before, but after hearing the video, don't you hear the airco compressor (dis)engaging?
Old Dec 10, 2016 | 07:48 AM
Mikey's Avatar
That's what I hear too.
Old Dec 10, 2016 | 11:23 AM
omgimali's Avatar
Thank you
Old Dec 10, 2016 | 11:24 AM
omgimali's Avatar
This happens when the climate control system is off.
Old Dec 10, 2016 | 11:38 AM
Jhartz's Avatar
At 2:04, the noise is A/C. Turn the A/C off (you probably have it in auto mode), then try again. Rest of the noise is normal. I hear some injector noise (normal), valve train and camshaft whine (normal). Actually pretty quiet.
But, I am confused: you said this noise was in your XJ8, but this video is the XK8? Same noise? If so, you are good to go. If not the same clicks at 2:04, then make your own video from you cell phone and post that. But first, be absolutely sure the A/C is OFF.
Old Dec 10, 2016 | 06:01 PM
omgimali's Avatar
Alright, I will do this tomorrow morning as the noise comes from a cold start.
