Are cluster instruments supposed to be hard to see in daylight?
Old Nov 8, 2010 | 08:11 PM
Boomer from Boston's Avatar
Default Are cluster instruments supposed to be hard to see in daylight?
I'm not sure if this is a problem or a "feature." But to me the speedo tach etc. on my XJ8 are hard to see in the daylight, even with the illumination cranked up as far as it will go. At least as compared to my other cars. If this is normal, are there brighter instrument cluster bulbs that could be installed? Or maybe LED replacements? No problem at night.
Old Nov 8, 2010 | 09:39 PM
I have seen online some so-called high-brightness LED cluster lights. Does anyone know what (presumably standard) type or types of bulb/socket Jaguar uses? That might improve the situation.
Old Nov 9, 2010 | 04:25 AM
Cadillac's Avatar
Hey , we have a member in X300 Forums Oudabah , you can check out his LED interior upgrade threads, different cars but at least it may give you an idea
Old Mar 16, 2011 | 07:25 PM
I wanted to pull this thread back up again. Now that the weather is warmer and I am running my XJ8 again, I continue to be surprised at how dim the cluster is during daylight.
Is there some sort of automatic circuit or sensor that sets the cluster illumination level during daylight? If so, maybe mine is messed up. Also, my car has aftermarket plastic window tint - could that be interfering?
I also note that the speedo and tach needles are orange and relatively bright near the center, but turn pale and dim out towards the ends. In forums for other cars, I have read postings where people paint or dye needles with fluorescent orange paint. Has anyone done that with their Jag?
Finally, if I wanted to experiment with a whole different cluster, is the mileage stored in the cluster or is it passed through from a different module?
Old Mar 17, 2011 | 04:19 AM
Sean B's Avatar
First off, you can upgrade to led, I have. You have to find led's that work for you, my first experiment, they were too dim, the next set too bright. It's a fair bit of messing around. Maybe refreshing the incandescents with new ones?
The mileage is stored in the cluster. It can be altered by a mileage adjustment specialist.
Old Mar 17, 2011 | 05:15 AM
DavidN's Avatar
The cluster uses pretty simple bulbs for the illumination.
I don't know the correct English word, but here's a picture:
Originally fittet are 3.2 watt.
I think you could easily upgrade to 5 watt.
(Availlable for repeater lights.)
IIRC there are 4 of them installed to illuminate the clusters and the needles.
David
Old Mar 17, 2011 | 10:15 AM
michaeldeanrogers's Avatar
DavidN's idea of increasing the wattage on the existing bulb seems like the easiest way to improve the brightness of the displays. Unlike LEDs, these do generate heat. My concern would be whether it would cause thermal damage over time with the increased temp. Does anyone have experience with this idea?
Forcedair1
Feb 19, 2020 01:51 PM
mhamilton
Oct 8, 2015 02:17 AM
xjrjag
Sep 24, 2015 10:08 PM
pk4144
Sep 24, 2015 08:29 PM
AL NZ
Sep 4, 2015 08:39 PM
