Code P102 - MAFS sense circuit low voltage
Old Aug 9, 2014 | 03:58 PM
Dan Hiatt's Avatar
Default Code P102 - MAFS sense circuit low voltage
When I replaced the TB gasket last weekend I removed the entire OEM air intake assembly. After putting it back together I got code P102, and the car went into 'restricted performance' mode. I had no codes prior to replacing the gasket. I finally got a chance to try to investigate the problem today. The causes are:
  • Blocked air filter
  • MAFS to ECM sensing circuit high resistance or open circuit
  • MAFS to ECM sensing circuit intermittent short circuit to ground
  • MAFS supply circuit open circuit or short circuit to ground
  • MAFS failure
I verified that the air filter is not blocked. I tested for voltage on the 5 wires and got the following:
Wire Voltage
black/yellow 1.0
green/yellow ~.35
white/blue ~.35
black/green ~.35
blue/purple ~.35
I am not electrically proficient, so I am not sure what to do now. Any suggestions would be appreciated.
Old Aug 9, 2014 | 06:20 PM
Sean B's Avatar
How's it running? if it's ok erase the code, did you disconnect the battery?
Old Aug 11, 2014 | 09:35 AM
Dan Hiatt's Avatar
It is running fine, just won't exceed 3k rpm . I did disconnect the battery when I worked in the TB gasket. I erased the code, but it returned immediately.
During my drive to work this am I had the OBDII hooked up. I noticed that the MAF reading was 0 during the drive, but the IAT was reading correctly.
Old Aug 26, 2014 | 08:44 PM
Dan Hiatt's Avatar
Okay, I was looking through the electrical schematic so that I could test the continuity of the MAF wiring. It was then that I noticed that one of the wires has a fuse in the engine management fuse box. Hmmmmm, pulled the fuse and... yep, blown fuse. Replaced with a new 10 amp fuse, cleared the code, and stomped on the gas. Man, I love that feeling!
Bcrary3
Feb 21, 2023 04:29 AM
Russ Graber
Feb 23, 2019 11:59 AM
OkieTim
Sep 8, 2015 04:48 PM
jaguarbill
Sep 5, 2015 11:43 AM
OkieTim
Sep 2, 2015 12:48 PM
