Codes PO0710, PO1111 98 xj8 base
Old Apr 29, 2012 | 06:15 PM
obriendob's Avatar
Default Codes PO0710, PO1111 98 xj8 base
Hi
I have been having troubles with intermittent "high transmission temp" warnings followed by the check engine light coming on.
The car runs fine. The warning message will come on at any time, whether the car was sitting for hours or running for hours. If the car is turned off and immediately restarted, the light goes out
I had a local shop rebuild the transmission last year. A few weeks after the rebuild I started getting the "high transmission temp" message. I brought the car back to the shop and they noted a faulty sensor and replaced it. No reoccurrence since that.
Aside from bringing back to the shop, is there any significance to the codes P0710 and P1111 I get when I scan ? 710 appears to be the sensor fail again
Bcrary3
Sep 12, 2021 05:41 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
corysansburn
Sep 10, 2015 06:15 AM
TexasCat
Sep 8, 2015 04:36 AM
