Collapsed radiator hoses
Old Aug 11, 2019 | 12:30 PM
Z07Brandon's Avatar
Default Collapsed radiator hoses
Was washing the car(2002 xj sport) this morning. I always pop the hood to wipe the engine down. Saw the hoses collapsed. I loosened the cap on the expansion tank, and the hoses returned to normal shape. What do I need to check to find the culprit?
Old Aug 11, 2019 | 04:31 PM
Highhorse's Avatar
How many hoses were collapsed, you only show 1. Feel them for pliability, ..when was the last time you replaced them? What had you been doing before that to heat up the system?
Old Aug 11, 2019 | 04:43 PM
Z07Brandon's Avatar
Pic 2 is also collapsed. It just doesn't show up on picture. I haven't driven the car, or started it today. Drove it yesterday evening. Normal drive. I've never changed hoses, otherwise cooling system is new.
Old Aug 11, 2019 | 05:00 PM
motorcarman's Avatar
The coolant cap is 'supposed' to allow the coolant from the atmospheric catchment tank to return to the reservoir when the coolant temp drops and creates the pressure differential.
There is something wrong with the cap, line or catchment tank.
bob
Old Aug 11, 2019 | 05:59 PM
Z07Brandon's Avatar
bob
Thanks Bob. The catchment tank is the one by the left tire, correct? I'll start the diagnosing by replacing the cap. The reservoir and cap are new, but we'll see.
Old Aug 11, 2019 | 07:42 PM
yeldogt's Avatar
That's just vacuum -- betting on the cap
Old Aug 12, 2019 | 01:59 AM
grantorino62's Avatar
Collapsed hoses is generally caused by low coolant in the system. You need to burp or purge the trapped air from the system.
KarmaPolice
35
Nov 26, 2019 11:34 PM
Anthony8858
Feb 16, 2017 02:11 AM
brgjag
Jul 29, 2014 06:01 PM
DaveC
Dec 22, 2012 02:21 PM
Mendo XK
Oct 4, 2012 11:45 AM
