Compression Test Results
Old Jun 23, 2013 | 10:26 PM
Safi's Avatar
Unhappy Compression Test Results
So my car has always had a random misfire light, and has been making clacking noises. I then decided to do a compression test just to see whats going on.
now i dont know which is Bank 1 and which is Bank 2 so i will say drivers side and passengers side for now.
Results:
95______65
110______70
105______90
110______45
. Front
(all cylinders were measured in PSI)
you can clearly see we have an issue on the drivers side bank
any suggestions as to what i should do next?
much thanks in advance.
Old Jun 23, 2013 | 11:28 PM
plums's Avatar
Look up how to do a "wet" compression test. That will tell you if it is more likely rings, valves, or head gasket when compared to the dry readings.
Look at your oil for the tell tale milkshake/mayonaise that is indicative of a head gasket failure. Also look for oil in the coolant, as well as performing a coolant test.
Old Jun 24, 2013 | 12:06 AM
MoscowLeaper's Avatar
Do you have a nikasil lined engine?
Check if a VVT is operating correctly on a drivers side bank
Check valve lash on a drivers side
Do a leakdown test and post a results - it will show what's the cause of the problem with compression - valvetrain, cracked cyl.head, bad head gasket or rings/liners.
Old Jun 24, 2013 | 03:25 AM
Safi's Avatar
Plums no oil in Coolant Res and no Coolant in Oil pan
Moscow how do i perform any of the tests you listed?
Old Jun 24, 2013 | 03:26 AM
Safi's Avatar
dont nikisil and non nikisil have different colored stickers on the engines? if so ill take a look in the morning, i doubt i will be able to see anything at night
Old Jun 24, 2013 | 03:44 AM
You need a leakdown tester to perform the test.
You'll need to set each cylinder in TDC, with valves closed and blow a comperssed air into the cylinder via spark plug hole. Air may escape a cylinder via:
-valves (hissing sound from exhaust or intake)
-piston rings (hissing sound from the oil filler or dipstick)
-blown headgasket (sound from the other cylinder or coolant tank)
Rivguy
Nov 13, 2022 02:55 AM
Jdthomas
Sep 23, 2015 06:23 AM
Papelione
Sep 21, 2015 06:13 PM
alextoevs
Sep 20, 2015 05:21 PM
corysansburn
Sep 10, 2015 06:15 AM
