coolant leak
Old Jun 10, 2011 | 06:49 AM
marshgrp's Avatar
Default coolant leak
I have a slight coolant leak in a part just above the water pump. Fluid is coming out of a crack in the top part. has the radiator hoses going into it. looks to be separate from water pump. What is this part? and how is it replaced?
Old Jun 10, 2011 | 08:10 AM
ronmexico's Avatar
It is probably the "water outlet pipe".It is hard plastic with several hoses attaching to it?
I had the same thing happen to me, it cracked and had to replace.
Old Jun 10, 2011 | 08:17 AM
JimmyL's Avatar
In addition to the "water outlet pipe" there is the thermostat housing, which is also plastic. You can find aluminum replacements. I'm planning on replacing all that plastic crap one of these days.
Old Jun 10, 2011 | 08:33 AM
yeldogt's Avatar
I would not delay getting it fixed - replacing with the metal part is the way to go.
Old Jun 10, 2011 | 01:47 PM
marshgrp's Avatar
Thanks Much.
arskemp
Sep 21, 2015 02:19 PM
Lannyl81
Sep 19, 2015 08:07 PM
OkieTim
Sep 8, 2015 04:48 PM
Xkr x100
Sep 6, 2015 08:50 AM
OkieTim
Sep 2, 2015 12:48 PM
