Coolant leak help..(video attached)
Old Jun 3, 2021 | 05:57 PM
asjdhsajhdfj's Avatar
Exclamation Coolant leak help..(video attached)
Hi,
I have an issue with a coolant leak on my car. It's a bit odd if I'm honest.
The leak only occurs from the left side not far from the tank, after I drive the car for a while or when I drive erratically.
Once the leak stops, I'll immediately refill the tank with water and the leak stops...
The video attached may not show much so I do apologise. (for some reason I can't add a second video but that was showing the leak from underneath.)
Any help would be seriously appreciated, thanks.
File Type: avi
Old Jun 3, 2021 | 08:39 PM
Highhorse's Avatar
That appears like a radiator seam...but the video doesn't show very much to tell.
Old Jun 3, 2021 | 08:41 PM
What would that mean? What could be the fix? New pipe, new radiator?
I'll try taking more videos when the leak occurs again.
Old Jun 4, 2021 | 05:40 AM
Highhorse's Avatar
Unfortunately, if its a seam, it would mean removal of the radiator. But, it could be a minimal cost repair for a radiator shop and all they have to do is solder it, pressure test it, and your good to go.
If the radiator would have to come out, a detailed inspection of your hosing and replacement of weak hoses, would be highly recommended. This should be done in any case.
Old Jun 4, 2021 | 09:39 AM
M. Stojanovic's Avatar
Difficult to solder as the core is aluminium and the side covers are plastic.
mikchek
Aug 17, 2018 06:06 PM
Drak
Dec 11, 2015 03:45 PM
Sonspit
Feb 19, 2015 10:26 AM
Muslima36
May 1, 2014 07:22 PM
sinatrakat
Sep 13, 2010 04:20 AM
