coolant level low,not
Old Oct 27, 2018 | 01:29 PM
ribbyp18's Avatar
Default coolant level low,not
I have a 2006 XJ8 that's showing a coolant level low warning even though the expansion tank is full, just like some others have posted. I have taken out the tank and cleaned it out and the float seems to move about freely. I also saw a tip somewhere else that said that too much water in the coolant could keep the float from floating. After removal, cleaning, replacement, and refilling coolant to level, the warning was gone...until about 15 minutes later. Could this be the sensor that needs replacement or the tank due to a possibly faulty float?
Old Oct 27, 2018 | 01:58 PM
Carnival Kid's Avatar
Ribby, you may have better luck posting in the X350 section, this is the 1997-2003 X308 section.
Old Oct 28, 2018 | 01:06 PM
ribbyp18's Avatar
Thanks Kid, done.
XJsupercharged
Oct 14, 2016 03:50 PM
nasomi
Oct 13, 2016 06:43 PM
WhiteTardis
Oct 10, 2016 12:31 PM
Don B
General Tech Help
Nov 9, 2015 12:59 PM
warekito
Aug 9, 2007 10:02 AM
