Coolant return tube.
Old Mar 22, 2017 | 05:35 AM
David Stevens's Avatar
Default Coolant return tube.
Hi all,
Not sure I called it correctly in the heading. I've been replacing knock sensors trying to cure a "restricted performance " code on my x308. Upon reassemble and installing the engine covers when I went to snap the two pipes onto their holders on the drivers side, the one from the thermostat housing was very brittle and broke in several pieces. It runs from the side of the thermostat housing to the back at the holding tank. Can someone please help me find a part number so I can reorder this. I hope you can understand my description of the needed piece. Without it the engine sprays coolant all on the right side.
Thanks all for all your help.
Old Mar 22, 2017 | 05:49 AM
Sean B's Avatar
David, have you not used Jaguars own parts site?
Jaguar XJ Series X308 parts | Jaguar Classic Parts UK
and your part
Expansion Tank and Recovery Bottle - Parts For XJ Series from (V)812317 to (V)F59525 (X308) | Jaguar Classic Parts UK
Old Mar 22, 2017 | 07:55 AM
I appreciate the guidance. I will check there . I am looking for a book or cd on my x308 with parts torque specs scheduled upkeep etc
Old Mar 22, 2017 | 10:12 PM
Rpach10115's Avatar
The part # for your car should be MNC4582AC.
Go to eBay and search this number.
They are new about $ 35 bucks
It's a thermostat bleeder hose.
Old Mar 23, 2017 | 06:43 AM
Thanks for the help. I'll get it on order!
