cooling fans
Old Aug 20, 2010 | 02:02 PM
beans's Avatar
Default cooling fans
radiator fans do not come on at anytime on xj8, fuses ok, if i connect fans directly to a battery they operate? is there a thermal switch on radiator as i cannot find one new to forum any help appreciated
Old Aug 20, 2010 | 03:44 PM
QuadManiac's Avatar
XJ8 (what year is yours?) are powered by the Radiator Fan Control Relay Module (RFCRM)- it has 3 relays that control the fans in one of four modes:
1 off
2 Left on full
3 Both on in series (half speed)
4 Both on in parallel (full speed)
The RFCRM receives its command signals from the ECM - two wires that control the four states.
Old Aug 20, 2010 | 03:53 PM
beans's Avatar
thanks very much
Old Aug 20, 2010 | 04:07 PM
QuadManiac's Avatar
You're welcome.
Here's a link where it's described in a bit more detail:
https://www.jaguarforums.com/forum/s...349#post234349
The wire colors mentioned are specific to the 99 model... and Jag changes colors yearly. What year is yours?
There are two fuses - one that controls the left fan and one that contols power to the right fan thru the RFCRM - they're in the Engine Compartment fuse box, fuses #12 and #14. But since your fans don't work at all, I'd guess it's not fuse related.
Good Luck!
mikiep
Dec 20, 2019 07:37 PM
Seth
Nov 1, 2015 12:17 PM
emilime75
XJ XJ12 ( X305 )
Oct 19, 2015 09:55 PM
LnrB
Oct 13, 2015 12:45 AM
workworkwork
Oct 1, 2015 01:44 AM
