Crank Pulley Bolt Removal direction
Old Nov 11, 2016 | 05:09 PM
DayOff's Avatar
Default Crank Pulley Bolt Removal direction
Quick question... if you're facing the front of the engine, what direction do you need force to remove the crank pulley/harmonic balancer bolt?
I read 'anti clockwise' on a site, which means pull the breaker bar from the driver side towards the passenger side (LHD drive, by the way)... is this correct? Is it normal thread, and not reverse thread?
I would have thought, if reverse thread, I'd be wanting to go clockwise (passenger side towards drive side) to remove the bolt...
Just making sure, as I'd like to keep my swearing to one direction.
Pete
Old Nov 11, 2016 | 07:59 PM
motorcarman's Avatar
The damper bolt is a NORMAL threaded bolt (righty-tighty-lefty-loosey).
bob
Old Nov 12, 2016 | 05:25 AM
Daim's Avatar
Anticlockwise... Like all screws (except a few on other rare cars)
Old Nov 15, 2016 | 07:57 PM
DayOff's Avatar
Thanks - always seem to have worked with reverse thread bolts for the crank... didn't seem possible, but sure enough, it came off
Pete
