Deleted middle muffler added x-pipe PICS
Old Jan 16, 2012 | 11:46 AM
Newby's Avatar
Default 2002 XJ8 X-PIPE what diameter? 2.25 or 2.5"
2002 XJ8 X-PIPE what diameter? I have 2.08" pipes as measured with a caliper, so I should buy the 2.25" (which is the smallest magnaflow makes) right? These should just fit over the existing pipes for a good fit I think...
Also does anyone make/sell CARB certified high flow cats for this application?
Old Jan 24, 2012 | 05:30 PM
Newby's Avatar
Default Deleted middle muffler added x-pipe PICS
Just a small dog and pony show. I had the middle muffler removed and put a magnaflow 2 1/4" x-pipe in its place.
The car does not seem any louder inside the car, but you can now barely hear the exhaust with a deeper (better) tone from the outside.
The butt-dyno says there is some hp improvement, probably similar to a good wash and wax job. I imagine I could get more HP gain if I put a sticker on the rear window somewhere.....
I would guess there is some actual hp gain, but less than 5 hp.
I would do it again.
2002 XJ8
Attached Thumbnails Deleted middle muffler added x-pipe  PICS-x-pipe-before.jpg   Deleted middle muffler added x-pipe  PICS-x-pipe-after.jpg   Deleted middle muffler added x-pipe  PICS-2012-01-17-13.27.30.jpg
Old Jan 24, 2012 | 05:58 PM
Stu 1986's Avatar
Hi
Add a video if you can of a walk round the car showing us what it sounds like. An inside one would be good too!
Looks like a lovely job, well done.
Old Jan 24, 2012 | 06:03 PM
Newby's Avatar
just a quick follow up. I used the 2 1/4" magnaflow x-pipe which was perfect for the job
Old Jan 24, 2012 | 06:56 PM
plums's Avatar
So ....
- what did you remove
- where did you put the X
- what does it sound like
Old Jan 24, 2012 | 07:18 PM
+1 ....no write up / video??
shocking ....lol
Old Jan 24, 2012 | 08:28 PM
ixj8it's Avatar
This thread is worthless without sound clips/video I have always toyed with this idea, but didnt want the car to sound too aggressive. Fill us in please!
Old Jan 25, 2012 | 12:37 AM
rverginia's Avatar
Any idea what effect that has on passing the emission test?
Old Jan 25, 2012 | 12:39 AM
Newby's Avatar
Originally Posted by plums
So ....
See Before pic (left thumbnail pic below) Removed big center muffler
See After pic (right thumbnail pic below) replaced with magnaflow x-pipe 2 1/4"
It is only barely louder in the cabin, just enough that you can now hear it.
Outside it is a bit louder, but lower mellower (better) tone. I like it.
I tried to make a video of it with my phone, but you could not hear the car over the background noise. (It is still that quiet) The change in volume is really small since I left the stock cats and 4 downstream mufflers in place. The difference is now I can barely hear the exhaust where before I could not. It is not remotely loud and it does not drone on the freeway. If I were to change anything else I think it would start to get louder so you would notice it, as it is, people might think it sounds stock, but a little healthier than the usual jag.
It does feel like the car breathes a little better and the butt dyno says I gained a tiny bit of HP
Old Jan 25, 2012 | 12:40 AM
Newby's Avatar
no effect, stock cats still in place
Old Jan 25, 2012 | 01:01 AM
JKo's Avatar
JKo
Is the pipe diameter same for XJR?
Old Jan 25, 2012 | 02:04 AM
plums's Avatar
The measurement is very close. Within the limits for measurement error, and the particular pipe measured. 1.96 inch OD using digital calipers just behind the front shared muffler.
Old Jan 25, 2012 | 07:24 AM
yeldogt's Avatar
Do you really think you are getting greater flow through the "x" -- it looks tight.
I have no experience with this change -- just asking. I don't remember the center resonator have all that much restriction. I did see the insides of the exhaust for my VDP ..... unfortunately.
Old Jan 25, 2012 | 11:05 AM
Newby's Avatar
Yes, a bit better flow. Even though the middle muffler has the two main pipes as straight see through, the material that the flow must travel through to equal the pressures out both pipes has some restriction. It it my opinion that this design (with the x-pipe) allows for easier equalization of pressures down both pipes which reduces the highest peak pressure in the previously larger flow pipe (the side that the exhaust pulse was traveling down before meeting the common muffler) I think that because there is less of a peak dissimilar flow between the two pipes, the the overall effect of equalizing the pressures is to reduce the overall loudness of that amount of total volume, but then you must add the volume produced because of the deletion of the muffling effect of the muffler, so the total volume is slightly more.......but with less overall pressure...... or I could be wrong...
My subjective experience is I like it better, and like cookie monster says
"C" is for cookie,
Good enough for me!
Old Jan 25, 2012 | 02:14 PM
XJR-99's Avatar
I am not sure about the diameter, but flows well and sounds good , even I have the middle resonator
Old Jan 25, 2012 | 05:54 PM
Newby's Avatar
OOOO, that does look nice
Old Apr 20, 2012 | 11:47 PM
jimmycruz99xjr's Avatar
Former Sponsor
<object width="400" height="266" ><param name="allowfullscreen" value="true" /><param name="movie" value="http://www.facebook.com/v/2060810217717" /><embed src="http://www.facebook.com/v/2060810217717" type="application/x-shockwave-flash" allowfullscreen="true" width="400" height="266"></embed></object>
Old Apr 21, 2012 | 02:55 AM
JKo's Avatar
JKo
Originally Posted by jimmycruz99xjr
(fixed that to a working link)
Wow, that's pretty loud. What exactly was done to it?
Old Apr 21, 2012 | 09:20 AM
Former Sponsor
Exclamation
well I wish I can get the link to work but I cant so ill make another.All i did was I deleted the resonators all 3 in the middle and also have a cold air intake has stock exhaust but im changing it to a magnaflow muffler but Does anyone know which one would be best?..sometimes there's is a cracking and popping kinda sounds like an old truck ...any suggestions?
video
Old Apr 21, 2012 | 10:16 AM
Sean B's Avatar
video
Can you put the video on youtube, it works - the facebook doesn't for me?
Here's two tweaked exhaust systems,
Borla from Adam699
1998 4.2 Jaguar XJR, BORLA no cats sound - YouTube
Paramount from me
PARAMOUNT CATBACK.AVI - YouTube
I like cracking and popping exhausts - the sound of a free cat not a strangled one
