Did Transmssion On '98'XJ8 Swap Got Stall Speed Error
Hi, I had a mechanic do a transmission swap on my 1998 XJ8 and the car has a stall speed error code. The fluid is full but in drive it takes a while to pick up speed but reverses fine? Does anyone know what could be the cause? The transmission was supposidely good.
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
If it takes a while to pick up speed, it sounds like internal mechanical fault, or possibly low fluid. Drive it by a Jag shop or dealer and have them take it for a spin, they shouldn't charge you. It should be relatively easy to tell if it's slipping.
Make sure the letters/numbers on the shifter surround match the corresponding gear ("D" lights up in drive and so on).
Thang Nguyen
Oct 12, 2015 01:25 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
