Did Transmssion On '98'XJ8 Swap Got Stall Speed Error
Old Sep 9, 2014 | 08:54 AM
dip2000's Avatar
Default Did Transmssion On '98'XJ8 Swap Got Stall Speed Error
Hi, I had a mechanic do a transmission swap on my 1998 XJ8 and the car has a stall speed error code. The fluid is full but in drive it takes a while to pick up speed but reverses fine? Does anyone know what could be the cause? The transmission was supposidely good.
Old Sep 9, 2014 | 09:52 AM
ServiceMasterD's Avatar
There's 4 possible causes:
1) Transmission oil level low
2) Transmission Selector cable adjustment / installation incorrect
3) Output speed sensor problem
4) Transmission mechanical failure
Old Sep 9, 2014 | 10:20 AM
Originally Posted by dip2000
Hi, I had a mechanic do a transmission swap on my 1998 XJ8 and the car has a stall speed error code. ........
Welcome to the forum dip2000,
I've moved your question from General Tech Help to X308 forum. Members here with the same model will be able to help.
Old Sep 9, 2014 | 10:24 AM
dip2000's Avatar
thank you. Where is he Output speed sensor located?
Old Sep 9, 2014 | 01:42 PM
RJ237's Avatar
In the transmission.
https://www.jaguarforums.com/forum/x...rmation-78132/
Old Sep 9, 2014 | 01:55 PM
If it takes a while to pick up speed, it sounds like internal mechanical fault, or possibly low fluid. Drive it by a Jag shop or dealer and have them take it for a spin, they shouldn't charge you. It should be relatively easy to tell if it's slipping.
Make sure the letters/numbers on the shifter surround match the corresponding gear ("D" lights up in drive and so on).
PMKimpton
Aug 3, 2019 08:22 PM
Thang Nguyen
Oct 12, 2015 01:25 AM
Guy-Pierre Boucher
Sep 16, 2015 05:55 PM
wcourt3010
Sep 9, 2015 04:34 PM
XCrossWindsX
Sep 5, 2015 10:58 PM
