Diming Lights at Idle with AC on
Subscribe
Jul 31, 2010 | 08:39 AM
hi - noticed this a few days...trying to figure out if it is a loose belt or a bad battery...when i am at idle with the AC on i notice the headlights dim...when i put it in neutral and give her a rev the lights get brighter...when i turn off the AC the problem goes away...so is it due to the strain the AC puts on the engine? or is it a bad battery...the previous owner just had a new alternator put in before i bought the car a few months ago so i don't think it is that..and i'd guess it wouldn't be the belts if a new alternator just went in, so i am betting on the battery but wanted to see what you all think...
Reply 0
Jul 31, 2010 | 08:45 AM
The accessory drive belt is held in place by a spring loaded tensioner so that is not the first thing to consider. It usually fails by breaking.
Battery or alternator/regulator can be quickly tested at your friendly, neighborhood auto parts stores.
Reply 0
Jul 31, 2010 | 08:52 AM
excellent - thanks
Reply 0
Aug 1, 2010 | 09:19 PM
i changed the battery with one from pep boys..a bosch one...and the problem went away no more dimming lights ...thanks for the info on the accessory drive belt
Reply 0
Nov 29, 2011 | 11:56 PM
hi all...my issue turned out to be my belts needing to be replaced...once they were replaced the issue i mentioned above is gone!
Reply 0
Subscribe
Currently Active Users (1)
