Disabling the Reverse Park Aid System
Old Jun 27, 2010 | 09:11 PM
rocklandjag's Avatar
Default Disabling the Reverse Park Aid System
I would like to take a rest from the beaping of the park assist sytem and disconnect it. I would not mind it if I could turn it down so that it was not so annoying but I think it is udner the rear deck cover. Maybe Jaguar hid it there knowing we would want to ahve a word with it if we reach it easily. Also, I have not found a fuse nor a relay that I can remove to silence it.
I think the little monster lives under the the rear deck. I see a huge wiring harness above the gas tank passing through the sheetmetal of the rear deck but there are so many wires in this harness that they can't all be the park assist, so i have not disconnected the harness.
Does anyone know an easy way to disconnect or quiet the park assist with out taking out the rear seat and back to remove the rear deck cover?
thank you for any tips
Old Jun 29, 2010 | 01:59 PM
Sean B's Avatar
1. remove boot board or spare wheel cover from the trunk.
2. locate fuse box a big black box towards the rear bumper on the left hand side in front of the battery.
3. remove cover via side clips.
4. locate the reverse parking aid sensor module, as in picture.
5. disconnect the left hand side connector of the sensors.
6. enjoy silence then a bump from hitting something you didn't see!
Attached Thumbnails Disabling the Reverse Park Aid System-dscf4409-medium-.jpg
Old Jun 29, 2010 | 02:13 PM
Delta66's Avatar
There is a switch next to the overhead interior light.
Old Jun 30, 2010 | 07:05 PM
Thank you for the help.
Sean B - Your point#6 is well taken about hitting something I can't see. If I do I will probably hate myself
When I start the car to back out of the garage it warns me that I am already hitting something.
Delta66 -I didn't mention that I have an 01' VDP S/C, mine does not have a button on the overhead console
I hope my car will tolerate my disconnecting the module. It may react like HAL in 2001 space odessey and and lock me out of the car. The message indicator may suddenly advice say "Please climb in the trunk to check for water leaks Dave"
"Daisy, Daisy..."
I had better rethink my plan!
Old Sep 28, 2010 | 10:13 AM
dneider's Avatar
If you have a broken sensor let me know. I have a few spares I need to unload.
Testing is pretty easy, emergency brake on, car off but in run, car in reverse. Ear on each sensor, listen for clicking sound. The one that isn't klicing is broken.
Old Sep 29, 2010 | 04:13 AM
Cadillac's Avatar
Originally Posted by Yourgirl0970
Is there a particular reason as to why I can't access Sean B's photo??? My sensor is not functioning and I want to see if the module has been disconnected.
Yep, you're a new member that's why you can't use all the features on the forums , mimimum 10 posts and two days or visit Jaguar Forums Help Center and hit your message here
https://www.jaguarforums.com/forum/s...t=35504&page=8
neruda
Oct 18, 2015 01:19 PM
ccfulton
Sep 20, 2015 05:15 PM
simo5555
Sep 9, 2015 06:22 AM
tberg
Sep 7, 2015 07:32 AM
mcdutch
Sep 4, 2015 03:38 AM
