ECM location on Vanden Plas
Old Mar 10, 2020 | 01:29 PM
Kenny Krylov's Avatar
Default ECM location on Vanden Plas
I am having trouble finding the ECM on a 2002 Jaguar Vanden Plas. Does anyone know?
Old Mar 10, 2020 | 01:45 PM
The thing behind the glovebox says F5SB-14A624-AA on it, that's all I can see without removing it. Google says it's a Ford ECM. Is this it?
Old Mar 10, 2020 | 02:41 PM
Carnival Kid's Avatar
I believe it lives under the toolkit tray, under the hood on the right-hand/passenger side.
https://www.sngbarratt.com/us/#!/Eng...DULE%20HOUSING
Old Mar 10, 2020 | 04:50 PM
avern1's Avatar
+1 Carnival Kid is correct. The module behind the glove box is the body processor module.I attached a diagram. If you are planning on replacing you will need the VCATS number to identify the correct replacement.
Old Mar 10, 2020 | 04:55 PM
motorcarman's Avatar
If replacement is required you likely need to have the 'IMMOBILIZATION-SETUP" done to be recognized on the CAN bus.
Old Mar 23, 2020 | 02:14 PM
Eyedooo's Avatar
Hi,
the module behind your glove box is the body processor module.
That has indeed a Ford part number.
If you need to replace the ECM you have to check your VCAT label for the exact version. The VCAT label can be found in the trunk left from your spare wheel.
But it is quite uncommon for them to fail completely.
Regards,
Alex
Old Mar 26, 2020 | 03:03 PM
aquifer's Avatar
I agree with Eyedooo - it is uncommon for them to fail. What issue are you trying to fix that led you to ask about the ECM?
mtotrainer
Aug 16, 2023 08:32 PM
Angelina Ruuuka
Feb 19, 2020 11:27 AM
CaptHank
Non-Jaguar Vehicles
Jun 19, 2016 01:06 AM
ragman1171
May 24, 2016 11:30 PM
JaguarXKR
Jul 1, 2011 09:10 PM
