EGR valve testing
Old Aug 18, 2009 | 11:56 PM
SoTxXjr's Avatar
Default EGR valve testing
Can anyone tell me how to test the EGR valve on a 99 XJR to determine if it is functioning properly? I'm trying to find the source of a vacuum leak or problem with the EGR valve. Hearing what sounds like an air leak from somewhere near the EGR valve. Any help or suggestions are greatly appreciated.
Old Aug 19, 2009 | 12:28 AM
poboyblues's Avatar
Your leak is located where the EGR bolts to the intake elbow....on the bottom of it. Either the 2 bolts are loose or have fallen out.
Old Aug 19, 2009 | 08:54 AM
SoTxXjr's Avatar
Wow. Either a common problem or you are psychic. Thanks!
Old Aug 20, 2009 | 12:21 AM
SoTxXjr's Avatar
Unfortunately not psychic in this case. EGR valve was bolted on securely. I did find the leak, however. Torn hose near the EGR from what I assume is the s/c bypass valve. Fortunately the tear was right at the hose barb and the hose was pretty long, so snip snip and all is right with the world. OK, not completely. See other thread here:
https://www.jaguarforums.com/forum/s...904#post133904
mhamilton
67
Apr 1, 2021 03:20 PM
Kevin Burnaby
Jun 28, 2020 08:04 AM
JWheeler
Nov 22, 2019 08:28 AM
Ozzy_UK
General Tech Help
Jan 14, 2016 02:52 PM
XFR_Gold
Sep 2, 2015 12:24 PM
