Engine oil smells like gas 98' XJR
Old Aug 25, 2014 | 11:24 PM
sean's Avatar
Default Engine oil smells like gas 98' XJR
Went to check my oil tonight and found blackened oil on the dipstick that smelled pretty heavily of gas. What could be the cause and the solution?
Engine had a blown head gasket not long ago which was repaired/replaced including all new seals and rings. Possible they weren't installed correctly?
Thank you,
Old Aug 26, 2014 | 09:00 AM
Jhartz's Avatar
It would be interesting to know how the car is idling and running. Sounds like some of the injectors are not spraying cleanly but spitting raw gasoline. Maybe a cleanup with Gumout or Lucas. Oh, and change the oil.
An OBD reader that can shows some details would be useful.
Old Aug 26, 2014 | 09:40 AM
Mikey's Avatar
Do not run the engine again till the oil has been changed. There is the possibility of wiping out the crank bearings.
fast40driver
Apr 19, 2024 07:24 AM
X_Type_South_Africa
Dec 9, 2015 05:37 PM
Thempsc
Sep 7, 2015 02:29 AM
peterg19
Aug 28, 2015 08:42 AM
dpappyp
Aug 27, 2015 06:31 AM
