Will a 1996 engine fit a 1998 transmission ?
Old 07-14-2008, 04:53 PM
Brake buster's Avatar
Default RE: Will a 1996 engine fit a 1998 transmission ?
i'm afraid the V8 didnt come out until 1997 for the XJ8 , so the 1996 car ( P year plate in the UK ) is a straight six engine xj6( x300 ) . or possibly a very early XK8 engine.....,
so no, it wont fit
the other thing about the V8 engine is the 4ltr has a different transmission than the 3.2 , so they cant even be swapped over
BB
Old 07-14-2008, 06:26 PM
Actuallly
The V8 for the XJ8 came out in 1998
The V8 also came out in the XK8 in 1997
And NO, the trans will not interchange from a V8 to a Inline 6
Just a clarification:-)
ericnunez (11-09-2023)
Old 07-15-2008, 11:38 AM
to be more accurate,
you need an 'AJ26 ' V8 engine,
the 'AJ27' came out in 1999 and had several revisions, including but not limited to .... electronic throttle advance and 4 wire plug coild over the earlier AJ26 2 wire plug coils , and second generation timing tensioners...
this may not seem a lot, but it means the ecu and engine loom will also be different....and AJ27 will fit, but you will need ALL the ancillaries to go with it
BB
D.K
12-10-2023 02:05 AM
XJsc-guy
11-23-2015 01:56 PM
arnoldmilk
09-03-2015 07:42 PM
OkieTim
09-02-2015 12:48 PM
TC Johnson
09-02-2015 09:30 AM
Quick Reply: Will a 1996 engine fit a 1998 transmission ?
