Engine/tranny jct oil leak?
Old Feb 2, 2014 | 10:34 PM
Blue_XJ8's Avatar
Default Engine/tranny jct oil leak?
Greetings
Lately have noticed a "quarter" size oil drop on the garage floor. Didn't worry too much about it until today. I had replaced the oil pan seal at last oil change and thought it may have been related. I did another oil change today and noticed that my pan and surroundings were nice and dry... To notice what appears to be the the junction between engine and transmission quite "wet", clearly confirming the area where the oil drop is coming from. The question is quite easy from this point.. What am I in for? Clearly not something I can attack myself so just need to be prepared for what I am in for (mechanic this is). All info / ideas / stories welcome.
Old Feb 3, 2014 | 05:09 AM
motorcarsrandy's Avatar
More than likely a rear main seal and/or rear oil galley plug that screws inn back of block.
Requires removal of transmission to access either so both should be done.
About a 7-8 hr job plus parts. About $800.00 repair
Old Feb 3, 2014 | 09:47 AM
Blue_XJ8's Avatar
OK noted, thanks. Guess need to brake the piggy bank...
Boeingtravel95
Sep 14, 2015 05:01 PM
jaggermang
Sep 8, 2015 07:07 PM
OkieTim
Sep 8, 2015 04:48 PM
Dymaxxion
Sep 4, 2015 02:40 PM
OkieTim
Sep 2, 2015 12:48 PM
